1 - 2 of 2 Posts
Can you rotate the outlet volute on a Procharger F1R? I have a big block Chevy in a 75 Camaro with side slinger bracket that I just put a 6-1/2" Sunoco hood on that is just touching the outlet casting of the blower. It's holding the hood up on the driver's side. If I can turn the outlet down about an inch would allow the clearance that I need. I prefer not to modify the hood if I don't have to. Thanks
Yes, just unbolt the Allen bolts it and turn it to the next bolt hole
1 - 2 of 2 Posts
