1 - 18 of 18 Posts
Does anyone make rollers for the rear bottom of a trailer? I'm having a hard time scraping the ground with mine pulling into the driveway which is uphill. If I back in, it tears up the driveway. If I pull in straight it scrapes the street. I'm really mostly concerned about tearing up my trailer though.
Does anyone make something for this, or do I need to fab some up with some heavy duty low profile casters? If casters would you suggest swivel ones or solid?
Thanks guys
I am a machinist, coincidently I just made a set for myself yesterday, all solid aluminum rollers with half in stainless axles and fasteners, I could post a pic but not able to until early next week at best, leaving town to go racing, they are very nice, can make you a set if interested, just pm me with a number. Tony
I found some rigid casters on McMaster Carr's website that are rated for 800 lbs each. I think the total weight of the loaded trailer is around 8000. Can I assume that the rear might see somewhere around the same weight as the tongue? If so, these should work. For $20, it can't hurt to try.
Discussion Starter · #4 ·
T Hall, thanks for the suggestion. I was thinking about something very similar to that. Did you use bearings, or just clearance a bit for a thru bolt? I'm no stranger to a machineshop either, and I need to get something in there pretty quickly. I'm moving into a new house this weekend, and just found out today it scrapes pretty hard. Yes, probably should have figured that out BEFORE buying the house :) but I'll deal with it.
They came on my 48ft Vintage, Pat Wheatly in KY sold it to me, it was thier demo, I am very grateful I have them, I had the all wheels off the ground once with the full load on the rollers!
Check with Pat, very easy to talk to.
They're called "bogie" (sometimes "bogey") wheels. Very useful. Trailer supply places have them. My trailer guy put them on for like $100.
I just used 2 1/2 in dia by 6in long, drilled them .515 clearance for 1/2 shoulder bolts. They dont need bearings no more than they will hit. If they hit.
1 - 18 of 18 Posts
