1 - 10 of 10 Posts
on a factory block (1970) 3970014 casting number, when using a small base circle roller cam .900 do you need a lifter designed for the small base circle? i see comp sells a lifter just for the small base circle
Banned
Yes. The lifter is taller so the link bars don't hit the block. Always a good idea to check the clearance between the link bars and lifter boss area.
Banned
Why are you going with the small base circle cam? I know of two reasons, crank clearance and to retrofit a non roller block.
Actually its increased rod clearance that is gained by going to a small base circle cam.
The retro-fit aspect does not come into play.
I just put together a 383 s/b with a standard base circle Comp Cams custom ground hydraulic roller into a first generation 350 block. Bought their best std height hyd roller lifters for it - $500. Running Eagle's "stroker" rods.
Had to clearance four rods a little bit. Depending on the rod used, on some applications, a small base circle cam is the only choice since the deck height of a s/b is 9.025 +/-
On my 406, it runs a small base circle Lunati solid roller with the same 3.75 stroke" but it has the Lunati Pro-Mod series 6" rods.
Banned
If yous wants to play.....you gots to pay !!
1 - 10 of 10 Posts
