1 - 14 of 14 Posts
Can a roll up barrel door for a shop be narrowed easily? I need a 14.6 wide door. I found a 16 ft wide used door for a couple hundred bucks in the paper. Can it be narrowed? Looks like it can be but I'm just not roll up door experienced at all.
Discussion Starter · #2 ·
anyone?
It depends on the doors construction. Wouldn't it be easier to face mount it and overlap the wall? I'm sure a good door guy can make it work.
SASQUATCH RACE TEAM
it depends on the door. we narrowed a steel fire door for my brothers building. we had to lay the door out flat then removed the drum. we cut the excess off the with a skill saw and steel cutting blade. the drum was not to bad. we knocked the end cap loose and removed the center shaft and spring asy. then cut then drum back. and reassembled it. it was a fair amount of work. but if the one you are looking at is the light weight one it might not be as bad.
Discussion Starter · #8 ·
Probably not worth all the work to me. I'll keep looking for what I actually need size wise. Thanks
Surface mount on the inside if you have room, most roll-up doors are surface mounted inside. if you don't have the rails or angle for the ends then it is worth scrap
depends if the screen is all one piece or individual slats. Best bet would be to overlap on both sides if you have the room
Discussion Starter · #11 ·
I added this 14.6 wide doorway building to an existing building to park a motorhome or trailer in and it is only 15 ft wide total so no way to do much with width. I probably just need to get a 14.6 wide door. Thanks again.
A guy told me the springs inside the drum would be a problem and I should pass also. Thanks anyway.
Between the springs, cutting the drum, cutting the slats, drilling out all the end guided, reinstalling all the end guids and cuting and reinstalling the bottom bar..... I'd pass.
The springs are inside the barrel and unless you have worked on these before, it's an easy way to loose fingers.
Door guys are like old railroad men, half of them are missing parts of fingers.
lol no one at our work missing bits of fingers:p
1 - 14 of 14 Posts
