How many of you are making the trip back to OSW for 275 vs 10.5 NonW.
Where are the rules again?How many of you are making the trip back to OSW for 275 vs 10.5 NonW.
Rules?? They were ment to be broken. So run what ya brung lol :smt071Where are the rules again?
Not enough time....Throw that Grudge motor in Corey....The rules are pretty liberal....
As bad as I am at saying yes it's not going to happen. Wishful thinking on my partThrow that Grudge motor in Corey....The rules are pretty liberal....
BBNOS @ 3100lbs & 88mm turbo @ 3300lbs. :smt110The Rules are the same, they are up on the new Orlando Speed World page. http://www.raceosw.com/dragway/flyers/2013/oct18-20/orlandoheadsuprulesOct12.jpg
Correct!NOSBB 3175 conventional head. Tip to Tip 88mm SB 3100![]()
It says single carb cast manifold deduct75lb. Not sure what tip to tip means. I read it as base weight 101 & smaller 3100lbs add 150lb for 88mm & 50lb for non inline head or am I reading it wrong?NOSBB 3175 conventional head. Tip to Tip 88mm SB 3100![]()
