1 - 2 of 2 Posts
can someone recommend the rings for a mild supercharged standard bore 350 chevy? 10psi boost, and 100 shot n20. pistons have 1/16, 1/16, 3/16 ring pack. its a real street car that sees plenty of miles and gets driven hard occasionally. i know to stay away from moly and other coatings because it dosent go well with boost or nitrous, and id rather stay away from hellfire since the majority of research ive done says they are not good for factory gm blocks due to excessive wear. any help and part numbers will be greatly appreciated.
Total Seal can set you up with a good conventional ring combination. You'll want a standard tension oil ring.
1 - 2 of 2 Posts
