Make sure and check cooler pressure . The few BTE ringless units I have worked on will get up in that 120 psi range with the line pressure at 220- 230 range.
Hutch have you seen this trend or am I out to lunch?
Transmission Specialties, Hughes and Coan make shafts for pumps with the TH400 Bushed support installed. And the new aftermarket for ringless shafts. That work with all the cooler system.
