Lol Pistons don't come with a gap sheet but the rings do . Kinda thought that was basic common knowledgelike he said...it depends on what the piston manufacturer recommends for your application....and they all like it different...pistons should have came with a gap sheet
gives you what they recommend times your bore size.....if not give them a call....
kinda thought this was basic common knowledge....
There should be a spec sheet with the rings follow that and you will be fine . How much boost you plan on running ?My motor's in the shop and all the machine work will be done next week what should the ring gap be for the rings the motor its a 512ci mopar with a 88mm turbo and C&S blow thru setup.
Thanks Mike
lmao....dammit....you got me on that one....ring manufacturer...my bad
Lol, I said throw out some numbers. Did they land wrong? :wow....really?? lmao
10 on the street and 20 at the track , I will check with the man. for the ring gap.There should be a spec sheet with the rings follow that and you will be fine . How much boost you plan on running ?
No problem good luck on your build10 on the street and 20 at the track , I will check with the man. for the ring gap.
And thanks for all the info
Mike
