1 - 5 of 5 Posts
· Registered
Based off man spec, Hellfire rings should be gap squared say 24-26 top and second ring in a boosted application(per 4.00 bore) apparently the trend is to open up the second ring .002 - .004 , my thing is that if they are gappped square already the second ring never sees the same heat therefore it will always be larger anyway ??? Granted man spec is usually just a starting point due to many variables, Whats right whats wrong ???
· Registered
You said what I have been wondering the top ring should be hotter therefor should be tighter gap compared to 2nd ring unless they are a different material....
· from across the pond...
They ARE different material. Stick to what they say in the spec unless you have data that says different on your engine.
Everytime my motor is pulled down i check to see if there is any sign of the gaps butting.If there is none i close them down .001". If there is i open them up .002". You need that data to make decisions on gaps other than oem gaps..
· Registered
You may need a larger than normal second ring gap to bleed of pressure build up between 1 st and 2nd ring otherwise this can lift top ring off its land.
As far as i can understand this is why piston manufacturer machine accumulator grooves between the two rings.
· Registered
that and to reduce ring shock if detonation occours. I still prefer to vent the second ring myself. It seems to help with stopping and or eliminating ring flutter. The second ring is basically a oil control anyways.
1 - 5 of 5 Posts
