1 - 4 of 4 Posts
How much does ride height effect the length of the drive line. I'm talking a rather large difference. S-10 stock height to 4" lowered? I need to order a driveshaft. Should I lower it first? Thanks!
How are you lowering it....
Blocks btwn the springs or flatening the spring...
Most cases the importance is measuring at ride height vs measuring it with the wheels hanging in full droop... where a leaf spring car can BE DRAMATICALLY different....from ride height to on lift or jack at the frame the rear suspension hanging....
So gm's can be a 3" difference from droop to ride height...
In your case it depends how you are lowering it, but it is best to have the measurement at ride height.
1 - 4 of 4 Posts
