1 - 5 of 5 Posts
I have a set of weld lites on the shelf that the off set is perfect on if I flip them around and mount them backwards. They are Black so I dont have to worry about the polished side. Other than the valve stem being to the inside is there a reason I cant run these like this until my new ones get here.
matter of fact i think you can drill another hole to put the valve stem in the new outside and weld sut or plug the old valvestem hole
I checked the clearance of the valve stem last night and I am going to have to remove the valve stem. It very close to the edge of the rotor and hits the caliper. Thanks for the replies.
1 - 5 of 5 Posts
