I got a 7AL3 with 2 kits I'm using a digi-set timer to activate the second kit. When I activate the second kit it turns the first one off.
The problem i'm having is when I use my clean out button on the second stage it want retart the timing..The clean out works fine on the first stage.
But when I check it going threw the timer it will retart. So why it want retart using the clean out button?
