1 - 2 of 2 Posts
I am running a muncie 4 speed with a 10 spline clutch. It has been in there for about 3 years. The clutch is a mcleod rst 6911-04. I plan on changing trans in the next two years. The car has less than 5000 miles since this setup has been in. Could I just put replacement clutch discs in to change the spline count? This would really save a ton of money. I love this clutch! I would resurface the flywheel when I did this.
Thanks Al!
Gigity
yes, but the new disc will not be worn to match the existing pp, and floater of the twin disc setup, so it may not hold as much as old setup.
1 - 2 of 2 Posts
