1 - 17 of 17 Posts
Is it ok to helicoil these or do they need to be welded up and rethreaded ? The threads were pulled out on several when the crank broke, on Dart Pro 1's if that matters.
Many are already helicoiled so yes it will be fine.
I prefer a Timesert over helicoils but yes they can easily be repaired without welding if they haven't been too beat up
Discussion Starter · #4 ·
Whats the difference in the 2
Nevermind, I found them on the web, they do look a lot better than the heli-coil brand, Thanks
If there is a structural issue in the head that originally caused the failure, such as an area that is too thin, a helicoil is not the correct method, you need some form of steel insert either made, or purchased such as the timesert... or, steel pipe plug is another good fix with a tapered thread which will give you a radial load around it... which, in my mind gives more strength.
many times when a common original diameter timesert has pulled out, you then only have the option to weld it up or to go to the larger outside diameter KINGSERT or BIGSERT.
Discussion Starter · #13 ·
Re: Repairing Rocker Stud Threads On Alum. Heads (Bad News !!)
Tore the heads down today, 7 out of 8 intake threads are pulled and 1 of them had a helicoil allready and has a small crack, maybe 1/2'' on the surface directly under the guide plate.The crack stops where the surface turns down. Can anyone pm me a price on what it would cost to weld that crack and machine the surface and install timeserts in all 8 intake stud holes ? All the exhaust are fine, the reason the intake gave way was due to porting made them a little weaker i guess since the have no bottom in them like the exhaust. These are Dart pro 1 230 heads ported by Rehr-Morrison in 2004. Thanks for any help on this.
Discussion Starter · #14 ·
Forgot to say what caused this, scat 4340 crank broke right behind timing gear. You can imagine what happened from that point !! Only damage was to the heads and valvetrain though.Really got lucky on that one.
Butch
Is this your fesh 400?
I dont want to ask but did you have a TCI or Fluidampr balancer?
Discussion Starter · #17 ·
No, its a motor i just bought, it had a scat 4340 crank and an ATI damper.Thats the second Scat crank i know of that has broke. Did not hurt the Little M block or the damper, just head and valvetrain damage.Needless to say, i wont use a Scat crank on this build.
1 - 17 of 17 Posts
