1 - 3 of 3 Posts
Lets say you have an aluminum block, or steel block, with the bores oringed for blown application with the aluminum heads having receiver grooves. If you have a head gasket problem and need to surface the block and the heads, how in the heck do you put the orings and receiver grooves back to spec????????????? Is it a hard thing to do or just everyday machine work???????
In the case of an aluminum block you would have liners that have the groove machined into them so just replace the liner . And for fixing heads or iron blocks you must machine the grooves into them , most shops use a tool called a groove-a-matic which i think was made by Isky . Pretty simple to fix and most reputable shops should be equipped to do it .
It's a little tedious, but pretty much normal machining stuff. When I worked in a shop that did that, we used a hand made o-ring cutter and carbide bits ground to different widths. You can go oversize on the wire and cut the groove accordingly as a "freshen up", or set the block or head up in the mill and cut new grooves. It's just a matter of getting the cutter square with the surface and matching the existing circle diameters and widths you're working with. It's time consuming, but not difficult.
1 - 3 of 3 Posts
