1 - 7 of 7 Posts
just about any hydraulic hose place can do it
A braided line or a rigid steel line? If its braided just google 'making AN lines' or similar, get a couple fittings and do it yourself. Takes about 15 minutes.
I've never seen anybody use screw together fittings on a nitrous line? Most of those are rated for like 300 psi.
I have the reuseables in stock if you want to cut it and replace it yourself. Still rated at 3000psi. Or you are more than welcome to ship me the hose and I'll repair it. Other option, depending on length, may be close to the same cost to just make a new one and ship it to you. Cut out the time and cost of shipping it here. Let me know.
is there anybody that can cut a feed line in half and make two shorter lines out of one?
If your talking about your SS over Teflon line we can do it for you. We cut these lines in two and shorten them all the time for guys.. Thanks, SJ
1 - 7 of 7 Posts
