1 - 4 of 4 Posts
I have a stock length rearend and need to chnge the axles, but the setup has CCE's, how do i get them out an re install new ones. its a 8.8 with 33 spline and full spool.
Thanks in advance ppl!
Pull the wheel off, remove the brakes, unbolt the C-clips it will be 4 bolts on the inside of each end, pull the axles out. To put them back it just to it in reverse order.
1 - 4 of 4 Posts
