I'm running into trouble trying to plumb a line into the upper port (oil in) on the block (KB Olds).
It's a 1/2" NPT threaded port, but it is so tight to the rear face of the block that without some clearancing, it's going to be near impossible to get any AN fitting in place. Anyone using this block...…...what did you use?
I'd like to get a 90deg., or 120 deg. fitting,(or ?), that will swivel to allow it to be installed.
Anyone have any ideas?
