1 - 7 of 7 Posts
Ive been running a CSR remote mounted water pump for several years. My motorplate has 2, -12 fittings that run to the backing plate of the pump and the pump is fed by a -16 from the radiator. I'm trying to switch over to a Davies Craig EWP 150 and now need to merge those -12 lines into a single -16 from the water pumps outlet. I found this Fragola Y but Id like to find something thats more compact. Maybe a manifold of some type. Does anyone have a suggestion? I just dont like how bulky this setup would end up.
Automotive tire Hood Light Motor vehicle Automotive exterior
Gas Auto part Machine Automotive exhaust Metal
Hood Bottle Grey Automotive design Gas
A Senior Member
Just an idea for you, I bought one of these for our BBC to use with our Davies Craig pump.
Maybe one of the boat guys can chime in with something similar.
  • Like
Reactions: rick90lx
Discussion Starter · #4 ·
I like that. Thanks
  • Like
Reactions: 69427
Discussion Starter · #7 ·
Thank you. That Earls piece is exactly what I need with my existing motorplate. I was thinking about buying another and just mounting the waterpump direct but not having any room is why I remote mounted it to begin with. Much appreciated!
1 - 7 of 7 Posts
