1 - 2 of 2 Posts
Anyone running a meziere water pump street application?
The reason why l ask is, lm about to put it on l have twin an16 fittings feeding pressure side of sbc, will have twin an16 coming out of thermostat , feeding the electric pump is only 1 1/2 hose inlet , something just doesn't add up.
You come out of the lower radiator port to the inlet of the water pump 1.5" hose.
The 2 outlets of the pump go to the front ports on the block. 1 each side.
The 2 port on the intake go to the top of the radiator. If you don't have 2 ports in the radiator then you will need to Y the line.
1 - 2 of 2 Posts
