1 - 2 of 2 Posts
Administrator
Its the amount of maximum amperage the solenoids will draw. Higher bottle pressures will use more amperage to open while lower pressures will use lower amperage. I would personally overshoot the amperage rating by 50% (if max is say 30 I would use atleast a 45-50 amp rely) for a safety margin.. Also if you are using a fogger make sure to add the total amount of all 4 solenoids..
1 - 2 of 2 Posts
