1 - 6 of 6 Posts
Have ran the car the same way for two years with no problems. Suddenly with no changes it starts melting the contacts in the relay closed after a few passes. So that it runs even with the switch off. I can put a new relay on and it will work fine for a while.
Ground issue? Something else?
Magnafuel 500 with a 40 amp relay if it matters.
Something is wrong with your pump, it is basically drawing more amperage.
i would say its the pump. mine started to blow a 30 amp fuse. sent it to Robbie at magnafuel had a bearing going bad. had it back within a week john
Thanks guys...I'll call Magnafuel tomorrow.
1 - 6 of 6 Posts
