1 - 9 of 9 Posts
The Megasquirt 3 has the capability. Maybe it would be a good thing to set the car up for Flex Fuel..
I believe almost everyone uses the GM Flex Fuel Sensor.
I use the GM sensor made by continental on two different vehicles. Cheap and works well, seems all the aftermarket higher priced ones are these with a sticker on them anyways.
I was told they have the same frequencies & was recommended to use the Continental VDO.... No real feedback yet.
As it was only 3/8” pipe,I didn’t want it on my fuel supply. I decided to add a take off on my return line & also went with compression fittings to AN. T from the return line passes through the Flex fuel sensor & returns to tank.
Good deal. I was thinking I would run it on my Return as well..
Good info...I am looking to convert from C16 to E85 over winter and was starting to research the sensor configurations and availability.
If you have access to good consistent E85 I wouldn't even worry with a flex fuel sensor. Even then if it wasn't a daily driver I would probably just use a decent tester and adjust as necessary. IMHO unless you are on the ragged edge a couple % either way doesn't seem to make any real difference. Just my $0.02
  • Like
Reactions: 7secTurboLX
T'd in the return is the only way I recommend running them. In line they can even restrict return flow causing fuel pressure issues at idle. If you are plumbing the system now, as in a fresh fuel system install, take a look at the Power House Racing Flex Fuel Sensor Dual Bypass. Here's the link
1 - 9 of 9 Posts
