I'm sure the degree of the touchdown makes a huge difference whether the impeller can be reused or not, but how tight are the clearances between the housing and the impeller. I was under the impression that they were only thousandths, so if that is true, doesn't any touchdown increase that gap after any cleanup, and therefore decrease the blower's capacity? What can be done after a touchdown to repair a blower? Can an impeller be touched up so the blower has the same potential as before? Centrifugals specifically in this case.
What steps would you take after a touchdown, other than cleaning out all the piping? Can you do anything to clean up the intercooler (A/A) ?
