1 - 2 of 2 Posts
i have caltracs and split mono leafs on my 67 camaro, right now i am using the factory shock mounts with autozone stock shocks, i am wanting to switch my shocks to the inside and install calvert -rancho rear shocks, comp engineering has a crossmember for 67-69 camaro, any modifications need to be done to the trunk? or top shock mounts on crossmember?
I have one Ill sell you cheap, It's new and I couldnt use it. If you are going to use the stud type shock you will have to beat up or cut out your trunk floor, If your using the hole on the side and a eyelet type shock you dont have to do anything, they fit decent but not perfect, I would probally weld it in. mine is cut to where you can only use the eyelet type shock. $70 shipped
1 - 2 of 2 Posts
