1 - 20 of 32 Posts
Hi everybody
i want to have som help for my rear axle gear
car monza 7.50 full tube car
weight 2470 on starting line
53% 47 % weight front rear
engine are a smallblock na 768 hp at 7500 rpm torque 585 at 6200 rpm
powerglide with 1.76 transbrake
converter 8 inch spragless stallspeed 6500 rpm (bolt together converter )
9 inch ford 4 link
tyres 32 *14 * 15
so i want to now what rear gear i should have with this set up
1/8 track 95 % of race
5% 1/4 mile race
i have 4,86 5,67 4,56 gears on the shelf
thanks
Hi everybody
9 inch ford 4 link
tyres 32 *14 * 15
5% 1/4 mile race
thanks
I’m going to be running a very similar setup. 7.50 car, same percentages, same tire, same stall, 1.80 glide, I’ll be 50lbs heavier, should be 80-100hp more and I’m going to try 5.00 in mine. I’m not saying my gear is optimal but I have 4.10, 4.30, 4.56 and 5.00 to choose from and went with 5.00. I will be 1/8 mile only. Of your choices I think I would try the 4.86. The 5.67 would be to much for 1/4 mile and possibly the 1/8 and I’m not sure it would be a lot faster in 1/8 than the 4.86. I’m guessing the 4.86 would turn a bit over 8k rpm 1/4 so it would be up to you if you wanted to turn it that hard.
Too Strong, For Too Long.
Hi everybody
9 inch ford 4 link
tyres 32 *14 * 15
5% 1/4 mile race
thanks
How many miles per hour does it go 1/8 mile? :confused:
1/4 mile it'll cross 7600-7700 rpm
1/8 6600-6700-6800 rpm
Discussion Starter #10
correct Cynic :)
but if i have stall speed at 6500 rpm and shift at 7600-7800
could the 4.86 ratio work on the 1/8 track
have had a 60 fot 1,22 best with 5.67
correct Cynic :)
Yes! If you can go 140 mph 1/8 mile, it'll cross 7400 rpm. :)
Discussion Starter #13
so what is the best for 1/8
maby i should by another one for this combo!!
or stick with the 5.67 gear
maby 5.13 or 6.0 or what do you think !!
sbc
768 hp at 7500 rpm
585 torque at 6200 rpm
stall 6500 rpm on shift ( racepak log)
32 inch weels
2470 lbs monza 7.50 chassie
585 tq x 6200 rpm / 5252 = ?
1 - 20 of 32 Posts
