1 - 16 of 16 Posts
Is anyone using this setup with ladderbars or is it more commonly used with 4-links? I was thinking about trying one with my setup. Any PRO's/CON's.........and info/advice would be greatly appreciated. Thanks in advance.
Wes
On these Ladder bar setups, are you running solid rod ends or Heim Joints? I was thinking about this the other day & I have solid rod ends in mine & it does not really rotate any. I would assume thats partly because the rod end wont rotate in the bracket & a Heim Joint will rotate on the ball.
Bob
you would have to rotate the axle tubes in opposite directions since the brackets are welded directly to them to get any body roll.i would never use a m/s heim for any suspension part under alot of stress,thats just me,less chance for failure.an anti-roll is pretty useless on a ladder bar setup
Discussion Starter · #7 ·
Bill G>
What type of heims come in the Art Morrison ladderbars. If I need to upgrade what do I need to get and where can I get it.............
Thanks guys for the anti-roll info.........
Wes
Adding one made all the difference in the world to my Malibu. It had a S&W rear frame kit. Tied to the cage. Bars were 24 inches apart. Car would twist. Adding an ARB changed the whole attitude of the car on the launch. All this was about 11 years ago.
1 - 16 of 16 Posts
