1 - 4 of 4 Posts
I run a 4 speed Lenco with a 2.83 low gear & 5.29 rear end gear, and 33.0x16.0 tire. Car with driver weighs roughly 2250lbs.
Engine: N/A 345cubic inch sbc. This motor likes rpms. 7800 off the line and shifting at 9500. The car feels like it stops pulling around 9700. Goes thru the traps at 9200-9300rpms
My question is would going to a 5.86 or 6.00 rear gear help the car pick up some or should I go with a different tire size?
With that 1st gear and rear gear ratio you are sure going to be busy pulling levers!!:p
1 - 4 of 4 Posts
