1 - 8 of 8 Posts
you can never go wrong with mark williams products i just got there powerglide yoke for the roller tailshaft
Mine looks just like that. Bought it from PST. Its a good think to upgrade to the stock flange is cast.
Not that brand, but I have a strange yoke which looks exactly like that. Pretty common upgrade to eliminate the factory pinion flange.
Curious, I see these yoke ends require 1350 u-joint, how do you go about making 1350 fit the standard aftermarket aluim driveshalf in which has the stock yokes now????
Discussion Starter #8
Im not sure what the Mark Williams is made out of but this one is made out of chrome moly and wanted to check and see if it will work.
This one is less expensive too.
David
1 - 8 of 8 Posts
