I just put new set viking rear coil overs on with 125# springs. To set ride height the right coil over is ran up about an inch compared to other side? Is this normal or ok??
Generally you don't set coilover ride height by cranking up the springs. You want the shocks to have the correct travel, which is what the spring height sets. Then you move the shock up or down on the mount to raise or lower car. If you crank up on the spring you are changing weight bias.
