1 - 15 of 15 Posts
How much can you push out of a stock block with a short fill 383 with a decent lower end, Dart Iron Eagle or similar heads, a single plane manifold, and a good blow through carb? This will have an air/air intercooler as well. It will be driven on the street on 93 octane pump gas, but raced on race gas. I know I posted a somewhat similar thread a week or so ago, but I want to see what could be done with a 70mm. Thanks...
550-600 and should live fairly well
On a bone stock 302 in my mustang with just an F cam swap I made 460 at the tires on pump gas(92 oct) and 11psi with a MP T70.
Contact VS Racing for the Best pricing on master power turbos!! 1-972-987-5607
They have awsome specials on www.theturboforums.com under sponcer's classifieds as well.
hope this helps
Travis
Custom Engine Shop
MP 70 are not true 70mm. And they work better on smaller motors, a 383 with mp or true 70 will only make 500-600 ish hp.
Alot of motor of a little turbo.
You would be better to look at a GT 76 or BW 75.
id have to assume a 70mm turbo on a v8 engine would be good but only if it does not rev too high. at that point(high rpm) the turbo would be choking the engine (exccesive backpressure/ boost falling off @ higher rpms) the cyls would still be filled with "dead" air, and loosing power.
MP T70 measures 69.1mm on the inducer and would be fine on a mild 383 using the .96a/r back housing. That turbo would have no problem making 650whp. If you want more, MP just released a 76 that should flow enough for 750-800.
Marshall
forcedinductions.com
get the borgwarner s475 i paid 617 shipped, 2 different hotside choices, the motor will breathe better and make more power
Nice to see you here Crowder...
I can vouch for the Green Firebird in Dayton....I have watched that car many times at the track and it flies.
I was there during a Diesel Truck race and I work for Valco Cincinnati Inc. I was most interested in the Firebird because I have been building my 74' Monte Carlo with a Single turbo blow thru set-up...
I just bought a 76mm Precision T4 .96 A/r that should work alot better than my 67mm I have now.
My car is 99% Finished...Just a paint spray and interior assembly from being done for now.
That Green Firebird really got me into gear to finish mine....I am running a stock 350 Chevy with the 67mm and .68 A/r housing turbine. Of course in my car right now it works great with the stock cam and 2.73 rear gear. I dont have to run much RPM for the car to hustle....It'll burn the drag radials all the way down the street. A engineer at my office swears my combo is good for 540 horsepower.
1 - 15 of 15 Posts
