2 passes on these plugs, burnout, shut down half track, then pull the spark plugs on the return road. I only pull 1(7) of my rich cylinders and 1(3) of my leaner cylinders just to cut time down changing plugs on the return road. (4 corner cylinders are usually rich). Cheater fuel solenoid, big shot nitrous solenoid and plate. 93n 82f. Recommended starting point from Monte. Im running 6lb of fuel pressure. If its rich where do you recommend me dropping the fuel jet to.
http://s1008.photobucket.com/albums/af207/ballaholic29414/Spark Plugs 10-23-2011/
