1 - 7 of 7 Posts
65 nitrous / 60 fuel
crossbar plate with IS solenoids
5 3/4 lbs. flowing fp
taking 16 from 34 total
sbc 430 23 degree head 1050 dominator 14 ro 1 compression
is this a safe starting point??
advise plz and thx
its a single stage crossbar plate
also what fuel pressure are you guys running this tune at
A65 jet is only about a 120 hp hit so id only take out 5* for thatim at6.5 lbs but you would probaly be at 5.5 lbs , i run c12 with 12-1 comp and shootin 450 total plates and fogger
The nitrous guy
I think he means "single stage" but he is using both bars, with a single solenoid, as the plate is designed. If that is the case, (2) .065 jets, should be a little over 200hp. Your tune sounds rich, especially at 5.75 pressure. .065/.052 at 5psi, will get you close quick. Timing around 20* total will be a safe start
Monte
1 - 7 of 7 Posts
