1 - 3 of 3 Posts
Has anyone seen any improvements in performance by raising their fuel pressure? I'll be installing one of the new Aeromotive pump in the next week and it has enough pressure/volume capability for me to easily raise the base fuel pressure from 45 to 65-70. I don't figure going higher is a good idea since I'm running Siemen Deka injectors and with boost the system pressure will be approaching 100-110psi.
The only possible benefit would be atomization .
if there is sufficient flow at the current psi there is no need. Imo .
1 - 3 of 3 Posts
