1 - 20 of 34 Posts
Better to go with 18's or 15's, the money for AFR RR's or All-Pro's along with shaft rockers would be better served going to a rolled head.
Premium Member
The only thing to consider is if you might end up running in any classes that require a stock valve angle head.... if you can't forsee anything like that in the near future then it's time to get away from 23 degree land.
I have been working on a new head to fill the gaps with the larger small blocks and higher revving small inch motors. It is a 235 cc 23* head that uses all std valve train. It goes 333 cfm @ .700" and is cnc ported in house. It is a really nice head if you are looking for a bolt on 23* package. I am building a 406 this week to put a set on to see what we can get out of them. I would think that they should make 680 to 700 on a single 4 with the cam. We will see in a day or two.;)
Keep me in the info loop. I am interested in that as to 11.25cr pump gas 434sbc. Thanks.
Aside from a 245RR All Pro, the normal thing to expect for a gain from, say, a 101 Bowtie or an 867 Pontiac vs. low port heads is 30 HP if both are prepared by a competent source.
I also agree its better to abandon ship on all that and move on to a more current cylinder head package. The only thing you accomplish with a 23° setup is "maybe" lower upfront cost.
Consider the fact that an 18°/15° or similar generally does NOT require:
- Domed piston (heavier & reduces fatigue life in the rods)
- Excessive spark advance (usually translates to a wider tuning window-less likely to get hurt)
- Deep valve pockets (23° pistons HAVE TO be taller to facilitate rod top end to piston underside clearance)
- Excessive spring pocket cutting or raised height valve locks (casting & valve integrity)
There are way too many good reasons to start off with something other than a 23° head for any real racing engine, and you (generally) will always make a SIGNIFICANT amount more power with the more current designs.
Discussion Starter · #11 ·
thanks for the response, I will also mention that I have a 421 18* 363 gm headed sbc that is pump gas but I was told it will not work because of the low comp, is this true because I was very disappointed to hear this. thats why I wanted to go with a rr head on the 434.
Currently building a 427,11.0 to 1,tall deck,pump gas,18* street motor.......
Should do 625-650 on motor and 400 more on nos and race gas......
Stock suspention 67 chevelle............
It`ll work.......
Banned
I am in the same boat. I have a set of 11X that are NOT raised port, just spreadport. I don't think there is too much more to gain with them with further porting. On one flow bench they were 320 through the intake, on another they were 308. I believe the second more, but it really doesn't matter. There isn't another 100 hp to be found in them.
What heads would be worth looking at? Not a heads-up car, bracket motor only. Reliability and low maintenance are the only things that matter to me. New pistons? Can I actually get above 14:1 with something close to a flat-top? Decent enough cast intakes available for these types of heads? Just looking at options for next year............
Everyone here has offered really good advice, .. unless you
have class rules to meet, .. drop the 23* stuff and jump to
18* or 15*.
There's some great deals on 18* stuff and a hand full of very
good porters for them, .. and you'll be happy you did.
Curtis
Curtis,
I have used Al before, and i`m really happy with the results.........
He was VERY interested in doing this particular project, so i gave him the green light...can`t wait to see the results......
Most people i talked with were leery of doing this motor with 11.0 to 1 comp..
They said it needed more........
It`ll work.......
I'll be curious to see how this turns out for you.:cool: A fella on the chevelle board did one of these 6-7 years ago. He used the Dart 18's. It made ~650 with efi.
1 - 20 of 34 Posts
