1 - 10 of 10 Posts
what kind of radiators are you guys using? im going to have a 540 with twin 88's. im hoping to do some street driving also. any suggestions? btw, i will be laying mine down parallel to the ground and size wise will be 21x19x4 roughly. any info would be appreciated! thanks, mike
what size is that radiator?
Buy the griffin rad that has 2 rows of tubes that are 1"-1/4" wide they might even make one know that has 1- 1/2" tubes. I have the 1-1/4" version which I believe is 31"x 19" x 2.5" it worked real good in my chevelle.
There are quite a few sizes available thru Jegs and Summit. Fairly cheap too. Some are dual row, some single and some crossflow. I got one from Summit (Norther brand) thats 24x19 i believe. 2in rows, and crossflow. Tigged the cap area shut and put on 2 -16 males. Had less than 250.00 in it.With a Spal Extreme 16in fan it should cool just fine.
Discussion Starter · #9 ·
and is that driving it on the street also?
Custom Engine Shop
Contact, Ron Davis, C&R or Saldana.
Have them make you want you need.
Top mount the fans blowing up. You will get less dirt under the hood.
1 - 10 of 10 Posts
