141 - 160 of 172 Posts
Ok.
Fill tank up front . That's where the radiator cap will be located..the thermostat housing to that tank..
From the tank to upper on radiator ..
From lower radiator .. Line to pump then the two -12 lines to front of engine..
Will there be an overflow tank or the fill tank takes place..?
Now if I have the intake steam ports tapped would those go to the fill tank?
I have a single radiator
Tank - one line going to intake and the other to the top of radiator ..
Do you have your steam ports tied into the same tank?
Looks like you don't use an overflow or catch can
Steam ports to the tank you have pictured. That's the fitting for it on the side of the tank pictured ..
Sorry for trying to get more details
