1 - 3 of 3 Posts
I did a search but did not find anything, having tire shake about half track and finish line. Is that a air pressure problem, suspension or just not applying HP correctly? Thanks
pig hunter
power? air pressure your running? tire size and brand? chassis setup?
Might not be tire shake......could be your driveshaft pinion angle is not correct.
When I ran the radial slick, too low of air pressure would cause shake in the first 60' or so. Only time I experienced tire shake down track was because the driveshaft pinion angle was off. It will feel like a tire is out of balance.
Hope that helps.
1 - 3 of 3 Posts
