1 - 16 of 16 Posts
Racing Question??
when your racing,and you get the Bye Run,do you run it through hard like you would if you had an opponet?
or just take it easy and coast down the track?
Racing Question??
If you want lane choice you do, or if you want to try something you do, BG
it would also depend on if your bracket racing..
you would want to to try and see what the car is doing to make your next dial in. if the weather has changed your car will run different..
T/S 368E
I go for my reaction time & 330' every bye run. If an early round, I will probably run it out.
If 4th-5th round, I have my time & weather station dialed in by then.
I would run 330' & save the stress & heat on the engine.
I find consistancy in trying the same amount each time.
Bracket racing...run it out, free time trial.
Heads up.. at least hit the tree.
Discussion Starter · #15 ·
thanks to all for the answers
I was watching the race on the internet yesterday from the 1320x,and a guy had the bye,and took it easy,thats where this question came from.
myself,make the full pass to check things out.
1 - 16 of 16 Posts
