1 - 9 of 9 Posts
Hi
have one channel left on my sportsman logger
what should you suggest for that channel
i have now
Iq3 dash
oil pressure
fuel pressure
A/F singel with several bungs so i can move it
pan vac
Rpm
volt
engine D/S ratio
Water temp
bluetooth dash
lateral g
accel g
have 1 channel left
what would you suggest for that channel
NA sbc with powerglide
thanks
think you can bye sensor for the sportsman v-net and plugg in to aux digital channels
trans pressure sensor was a god suggestion :)
Discussion Starter #6 (Edited)
and with the 500 hz module it wont take up any channels on the racepak sportsman logger
so i can have shock travel and transpressure :cool:
Any reason you are watching lateral g's?
Carburated (no TPS)?
I really like dual O2's for pinpointing flaky spark plugs when the rpm is logged at a high enough rate.
Laser chassis (front end) height?
Discussion Starter #8
if i want to se small movement on track sideways , at no prepp i use it to see where on track its going sideways and how mutch
yes carburated
1 - 9 of 9 Posts
