It will record some times, I have a rac pak tach and when my guy turns on the switch the tac will come on it will flicker and either work or shut off. shut switch back off and on and it will come on and flicker again if it stays on it records the whole run, if it shuts off nothing. It seems like a signal problem could the tach be bad and hogging the signal from the grid??
