1 - 1 of 1 Posts
Motor is 548 with 14 to 1 compression. It was dyno tuned//set up on Sunoco 112 but may have problems getting it when I want it. What is a compatible fuel I can use without changing the tune. The speed shop nearby sells only VP but is more expensive but if I need to go that route I will so what VP grade would I need to be close to the Sunoco used now. Thanks
1 - 1 of 1 Posts
