1 - 8 of 8 Posts
what is better to run and why a thermostat or a water restricter what kind of problems can a thermostat give you
You should run a restrictor of some sort to make water pressure behind it so the water does not just follow the path of least restriction and not cool properly giving you hot spots
I agree. Run some sort of restrictor or even a gutted thermostat will only have about a .75" hole or less in it.
I run a thermostat with a 1/4" hole drilled in it so there is always flow but the motor comes up to temp faster.
1 - 8 of 8 Posts
