1 - 16 of 16 Posts
Hey guys just wondering, my street car runs pretty good for what it is I think, just wondering what some other people have done with a 350. My 89 camaro went 10.23 at 132 with a not so great 1.64 sixty (usually 1.40-1.44) on one small kit 150. Just wondering what some others have done I,m sure somebody has been lot faster just curious how much faster.
Discussion Starter · #2 ·
By the way I am useing a cold fusion two stage cross bar plate. Wondering what some others have ended up with as far as tune up.
I went 10.19 @ 136 with my car years ago with a 10.5 to 1 355 with a set of ported 292 turbo heads. That was done on a set of 275 BFG's and before I had the chassis totally sorted out. I'm sure I could put that motor into the 9's today if I still had it. It was one of my favorite motors and ran great for the few $ I had in it.
Younger days
Growing up way back when, this was probably late eighties or early nineties but I had an 81 Z/28 street car, with 9 inch slicks and a roller 355 with a Cheater NOS system in went 6.60's on a regular basis. Never ran it 1/4, it was a low comp. street motor though.
Then they started enforcing having a cage in the car, and was asked not to come back till I got one in the car. Pretty sure now you culd make one a lot faster than that. Especially in a light car.
Well I'm at least in the ballpark. I thought it was pretty good the car weighs 3340 with me in it, stock suspension 275/60/15 mickey radials mechanical water pump and fan. Thanks for feedback
Banned
Out of curiosity do you remember what cam was in the engine?
How much did you spray it using pump gas?
I think I may have the old cam card in my tool box. I will dig around for it this weekend when I'm in the garage. It was a comp solid roller in the mid .500 area. Those times were on a 225 shot.
My 3100 lb 69 camaro ran a 6.28 (1/8th mile) back in April with a 200 shot. The car has a 355, 10.1 comp ratio, cam motion custom grind, AFR 210's, pro-systems card and TH 400. That was done footbraking the car off the line. The car is getting the cage upgraded right now and getting a parachute mounted. I plan on increasing the nitrous, launching off the T-Brake and hope to get into the 5's.
i went [email protected] in my rx7 with a 358 ci pump gas small block chevy with a progressive and a big shot plate ..350 in the plate ..
the car was around 2800 lbs and went 10.6 -10.7 on motor with a solid flat tappet cam ,and performer rpm heads that were well gone through ..
heres a vid of testing on a 150 hit 1st night out with new suspention 9.5 @141...
if the vid says unavailable click the veiw in high resolution on the right
http://www.youtube.com/watch?v=_FnajsbZNHE
i like this thread it reminds me of the early days of street racing. i had a friend that had a 355 stock bottom end fresh with cast pistons small cam around 230 at .050 and 480 lift with smog heads and a 250 shot it ran mid 10s for 2 years before the pistons disappered he made alot of money street racing it and only had about 800.00 in it total. those were the fun days
Had a 64 velle with a stock 400 sbc and a plate.....Painted the valve covers on the hood...without covering the hood......2x4 in the passenger spring, instead of air bag....9" slick...ran bottom 10`s and made money street racing it for a while......good times.....
Car was a REAL beater!!!!!!!!
1 - 16 of 16 Posts
