1 - 10 of 10 Posts
For 4500 holleys who has the nicest brakets for a tunnel ram set up two carbs ..... Thanks
They have great linkage kits but I can't find a bracket for the throttle cable to go on too. They have it for superchargers but not tunnel rams.
Anybdy?
Typicall, if you look at the dragparts.com site, the arm from the linkage to the throttle cable points out at about a 45 degree angle.
There's then a secondary bracket that bolts onto the manifold at the base.
From this bracket, you have a shaft with a 90 degree elbow on it. The throttle rod attached to one end, while a shaft is vertical attaching it to the carb lever that is hanging out at a 45 degree directly above it.
If you have a cable system instead of a factory style rod setup, then you'll have to fabricate your own bracketry.
Alternatively, you may be able to adapt something like this:
1 - 10 of 10 Posts
