1 - 9 of 9 Posts
Anyone have an idea my current combo 496 bbc dart pro 1 345 ported, dart intake, bullet cam 780 in 276 805 ex 288 114 3485lb car 33 10.5w 4.86 gear 9 inch converter 5200 stall on brake. Best so far on motor is 9.70 138 about 7200 through traps. gonna spray 200 shot any guess as how much i will gain and at what rpm do you think i will go through at. I don;t really want to spin much higher than 7800-8000 bottom end is eagle with arp bolts srp pistons 12.9-1
EFI/N2O JUNKIE
I would expect your 5200 stall to become 6400 or so. If you tune it and actually can get a 200hp increase you should go 8.80 or better and should be less than 8400 thru the traps.
do you think it will live that high in rpm or would a gear change be in order?
EFI/N2O JUNKIE
The rpm question is up to you and your engine builder (and your connecting rods & valve train.......).
If you can't get a taller tire you may need to go down in gear.
Make a pass and click it at the 1000ft.
If you have never shot it before you should only be making 1/2 track passes (1/8) and checking plugs anyway. 200hp is a very strong starting point and can hurt things fast.
Thanks for the advice, we do plan on some smaller hits and tuning up to 200 shot.
EFI/N2O JUNKIE
Start at 100hp and you can't do too much wrong to hurt something.
Hell, to most on here a 100hp shot is a good frickin' purge! ;)
A lot run .040's in their direct port, I was running a SINGLE .040 in my plate........ :)
Discussion Starter #7
anyone else have an opinion
I would say half track it as well. If it seems it is going to be safe for you leave on it and see what she'll do. Me personally I'd get rid of the 4.86 gear and aim around 4.30. A taller gear will keep RPM low and also Nitrous increases Tourgue Tremendously at lower RPMs. Good luck and keep us updated.
1 - 9 of 9 Posts
