question on cam, cubic inch, and nitrous:
I have almost everything to assemble a big ci sbc (450) but was wondering about nitrous. originally I didn't plan for the spray but don't think I can resist. So my question is how much can I successfully use with my combination without too much trouble. I know the LSA play a big roll here so what are your thought.
Specs:
Dart raised deck iron eagle block 4.160 bore
4130 steel crank 4.125 stroke
H beam rods
11:1 cp ratio
cam solid roller (custom grind)
258 268 @ 50 .720 lift int .740 ex 112 LSA
short rod ratio (1.45)
ported GM sb2.2 heads
port type nos (not sure of system yet)
trying to decide if I can use enough to warrant the hellfire rings or just stay with the moly & how limited am I with this combination on nitrous
thoughts?
mike
Specs:
H beam rods
11:1 cp ratio
thoughts?
mike
