Who's running a standard Star Vacuum Pump with Star's filter cannister and -12 AN clear hose with wire?
I need help trying to isolate a vacuum leak or if I don't have the regulator turned in enough.
2 Cars same setup with same low pan Vacuum.3.8 at WOT.
Question is how do you seal up your hose to the pushlok fittings?
And how far do you have your regulator turned in?
