I hate to keep posting so many questions but I REALLY appreciate all the help you guys do to help people. I really do.
I FINNALLY got my nitrous system complete and stuck the car on the dyno and im getting some VERY weird readings. here is the my combo
2.0 zetec ford svt focus DOHC (think 4 valve mod motor head)
13:1 compression
ported head with softened chambers.
230/220 cams
sheet metal intake
direct port NOS fogger nozzles
stand alone for the nitrous kit using 1 gal cell and holley regulator.
running e85 in the car and the c16 in the nitrous kit
28/28 jets in the nozzles flowed at 4psi
pulling 6 degrees from the base 26 degrees
my question is on the dyno when the nitrous hits, BOTH my wideband in the car AND the innovate on my dyno both peg lean (19:1 AFR)
does not lean pop or anything just goes way lean in 2 gauges.
tried going from 3 psi to 10 with no affect on the afr what so ever but does effect power output so I know its changing it. I have not done a full pull as I am terrified to not knowing what the afr is actually doing.
have confirmed that the fuel solenoid is working and the fuel pressure stays stable when the kit is on...
now my question,
if this because both widebands are on a gas scale and im spraying two different fuels? what I mean is since the car runs on e85 and the kit on c16 is this somehow screwing with my widebands and its not actually lean?
reading the plugs is not really an option as these heads use a special plug that is $14 a piece. I REALY don't want to have to keep replacing plugs every single run until I get it somewhat close on the tune.
the car does not fall on its face or anything and seems to pull somewhat smooth on the dyno chart for the few thousand rpm im in it.
sorry I am long winded but not sure who else to ask.
thank you guys so much....
13:1 compression
230/220 cams
sheet metal intake
now my question,
