When using quench dome pistons, specifically this one
http://www.probeindustries.com/Chrysler_408_17_5cc_Reverse_Dome_SRS_Pistons_p/13744.htm
how do i go about setting quench? I know with a flattop I can zero deck the block and use head gasket thickness to dictate where I want it, but when using the reverse dome, what is the procedure?
Im going to be using a .040" head gasket, so would i still zero deck and get quench off of the flat part of the piston (quench pad?)
Sorry if im not explaining myself here, or if this is a stupid question, just want to be sure...these are the pistons im going to be using in my stroker build
thanks!
thanks!
